Jim
- Dec 18, 2019
- North Carolina
- London Aire 4551
- Freightliner
- Cummins / I6 Diesel Pusher 600HP / 1,950 ft-lbs
- 2016 Jeep Rubicon
@RKins, I should have mentioned, the treadmill design has a 2" valve in the bottom where a large input/exit water line is to be attached. In a commercial setting, the operator would turn on the water source and the water would rapidly fill the tub from the bottom.
After the treatment, the water could be dumped, or recycled, into wherever the water source was coming from. My application is a temporary setup (I hope), so all the supporting equipment is being replaced with a "water hose".
And the water source is a 1,000 gallon tank supplied with spring water, so water is free and gets dumped onto Trish's plants when we're finished.
