Engine won’t shut off: Part II
TJ&LadyDi
RVF "Dinosaur"
Washington State
Now I know what Alice experienced when she went “Through the Looking-Glass!” And, I understand the full meaning of “You can’t get there from here!”
The problem of the Cummins engine not shutting off is intermittent; we haven’t found any pattern to it. The local shop working on it at the moment says they can’t diagnose the problem unless they have it in failure mode, and it won’t fail for them despite numerous attempts. It has failed just fine for me more than a half-dozen times including yesterday morning here at the RV park.
Spartan took two days to answer the local shop tech’s call for diagnostic help and says all it can do is send some schematics. Newmar says it is either a Spartan or Cummins issue. Cummins says it is a Spartan issue. Spartan says maybe its a Cummins issue. And, the problem continues…intermittently!
Spartan says the emergency shut-off procedure is to use the chassis battery disconnect switch. It worked the first time we tried, but yesterday it didn’t. Spartan says it should always work. The local shop says maybe we need to also use the coach battery disconnect too. Spartan says that’s unnecessary. Cummins says “huh?” Newmar says its either a Spartan or Cummins issue.
We may just have to let it run out of fuel the next time it happens! :mad::mad::mad::mad::mad:
Anyone out there ever experienced this kind of an issue? What was the solution?
I don’t know the entire history or backstory to this issue but by any chance have you replaced the ignition switch itself? Also just curious if the ignition switch itself is bad would that fall under Newmar or Spartan?
We have not replaced the ignition switch. As yet, I can’t even get anyone to diagnose the issue. Since the coach is three years old, Newmar is out of the picture as far as warranty. Our Spartan warranty ends tomorrow, though they do have an active case filed. We have two years left on the Cummins engine warranty. And, I’d gladly pay out of my pocket to get this fixed.
I don’t want to start tearing into it myself unless that’s a last resort as both Spartan and Cummins would likely wash their hands of the problem.
never experienced anything like this but the ignition switch makes the most immediate sense to me.
The chassis battery switch not working it particularly confounding.
Are you sure Lady Di isn’t standing behind you making diesel engine noises just to mess with you?
I mentioned on your other thread that I had had the exact same issue on my previous 08 Fleetwood DP. It didn't have a battery cutoff switch so the only way I could kill the engine was to disconnect the starting battery which shut the fuel supply valve, killing the engine. It happened 4-6 times and I had planned to have it taken care of when we returned home but it never happened again in 5 years and 40,000 miles.
As a note, those of you familiar with the Gafney FTL service center will remember Pat, I called her while on our trip and she said they had it happen to a relatively new coach. They kept the coach for several weeks starting it many times each day and they never duplicated the problem. She was convinced it was a Cummins issue, for what that's worth.
I assure you, as long as I owned the coach, I said a little prayer and held my breath every time I turned the key off.
Hmmm, replacing the ignition switch might be the fix, but, just have them take it out, but leave it hooked up, see if it's arching, lose connections, etc. Having it hanging down will not affect it's function, and then it can be looked over. Great Call forum. Ok, years ago, dad had Chris craft boat, and the switch went bad, he was not mechanically inclined much, but he took it out, went to dealer, and they showed him how to take apart the key part from the switch part, sold him a new switch part, he put the key part back on the switch part and then reinstalled the switch, believe it only had two wires on it, but this is like over 50 years ago.
Today I would take a serious bet, the whole assembly is made in China, very poor quality control, and also very poor manufacturing oversight. It's very possible the switch is going bad, and the contact inside is getting worn, and not working all the time. This is where I would start since you are getting nothing but a run around from the powers that be. I am not sure how many connections are on the back, and don't know if it's also is a two piece unit, i.e., key/switch parts. It's worth looking into since nothing else is showing up, not even codes if I understand this. Spartan and or Newmar would more than likely send you a new unit at no charge just to have the issue resolved.
And, unless nothing else works, I would not take the battery cable loose unless that was all that was left, just giggling the switch does not seem to clear the issue assumed.
I’m a big believer in prayer, Jim, but I’d rather not have to use it to turn the engine off. ;) It has happened to us 6 times in the past month. There’s no discernible pattern. First, I thought it occurred after the coach sat for at least several days. Then, it happened twice in one day. After that, it didn’t happen again for a couple of weeks, during which time the engine had been started and stopped numerous times. And, then it happened again yesterday. Maybe I’m not holding my mouth right when I turn the key off. :ROFLMAO:
I'm trying to remember and thats a stretch, but I think when I turned the key off, some of the dash warning lights came on. FTL had me pulling relays, fuses, etc trying to kill the engine and nothing helped. I did get proficient in removing the battery cable. Like I said in my previous post, it happened those 4-6 times in a period of 2 weeks and never happened again.
My $0.02 ... Can you devise a testing routine to verify which circuits should be live and which should not have power for the next time this happens? Then when the symptoms arise you can perform your testing process to determine faults, if any.
For instance, determine a routine to test the circuits to the key switch (which ones should have power, which ones not), test routine for the shut off solenoid circuits (same), etc. As you work through the potential causes the issue(s) should become somewhat clearer.
Hopefully, the next time it happens you have a plan, and can find a safe location to run through the testing process.
At least this way you can busy yourself without becoming over stressed :)
TJ, is this related to driving? i.e. has it occurred just starting in a camp site then shutting down or is the transmission out of Park? Air brake released? I think in your coach and up they start tying things into the air brake circuit.
Neal excellent point, however, I have not tried to put coach in drive, parking brake off and turned off engine. Guess its something to try. But, in neutral, parking brake engaged, then try to turn off, see what happens.
I also updated post above with story about switch in boat. Please advise once something is found. FWIW-General Motors and some additional car manufacturers a few years ago had a bunch of ignition switch start to cause problems, in fact believe GM was sewed over the problem since NHTSA did not issue recall. The solution was to only have one key on switch because of the weight wearing out the bearings in the switch, you might have one of those bad switches, even if the key is not shaped like GM, it still could have guts of that type. See post above.
It seems to happen when I start the coach to air it up prior to bringing in the slides. I let it run for 5-10 minutes and shut it off (or attempt to) inn order to bring in the slides. Intermittently, it won’t shut off at that point. It has taken as little as 2-3 minutes of cycling the key on and off to get the engine to shut off; or as long as 30 minutes. I haven’t had it fail to shut off after the coach has been driven any distance. Hope I haven’t given it any bad ideas in that area now. :oops:
Yesterday, it ran for 30 minutes with me periodically cycling the ignition switch on and off. When the tech arrived from Premier RV Services, he tried the switch and…naturally…it shut off on the second try. I’d say that the coach just hates me, but it has happened twice to LadyDi and nobody or nothing could hate her. ;) After I finally got it shut down yesterday, I brought the slides in, restarted the engine and drove the coach about a mile to the Premier shop. It shut off fine upon arrival and the techs started and shut it off at least 20 times successfully during the day without a failure. Go figure!
I have tried releasing the parking brake, putting the transmission in Drive, etc., and then going back into Neutral with the parking brake on, but it still wouldn’t shut down. What I haven’t done…and need to do…is to check and see if the dash gauges stay on when I turn the key off with the engine still running. Sounds like something I would have noticed, but I’ve been too focused on trying to get the thing shut off.
My problem was always after lots of miles. The first time it happened, I was doing my outside stuff and my wife would shut it down after it had finished leveling. I noticed that she hadn't shut the engine off for quite some time. When I went in I asked why she hadn't shut the engine down and she said "I did". Thats when I noticed the lights on like when you first turn the key on and it brings up certain warning lights. I spent almost an hour with FTL on the phone trying all kinds of things to shut it down. I must have turned the key off 50-75 times. That is when they instructed me to remove the battery cable. The same thing happened the next day when we arrived at our next overnight stop. I tried the key a few times before simply removing the cable. It happened another 3 or 4 times and never again.
TJ - Going to assume, you have to do the "leave the campsite" the same as I do. I leave coach plugged into shore power, make sure the Oasis is off both diesel and Elec, antenna down, etc. Then raise leveling jacks, and start coach. As coach is airing up bags/brakes, coach attains ride height, and I then shut down engine. Have never had key not shut down engine. After reading all the posts/comments herein, I really think you got a bad switch. Could it be this simple, well, if everything else has been checked, that is the last thing in the chain. And it will not happen every time, just randomly, because that is the nature of the contacts in the switch. So see if they can change it out, and if that fixes the problem. I also believe, there are more than 3 wires into it, one of which is turn off fuel solenoid, one is kill 12V power to gauges, so if the contacts are bad, the gauges may also not go off, or that contact is good and they do. Regardless, check this out. Now all can laugh at me if turns out not to be issue, but nothing else has shown up the way I read it.
Although not germane to your coach, this freightliner chassis diagram shows the ignition switch, and you will note more than three wires off/in to it. If I am reading it correctly. Maybe this will help you, I'll take beer bet, the switch in spartan and freightliner is either the same or a very close cousin switch for both.
@TJ&LadyDi do your slide motors not operate when the engine is running? It’s beside the point but I am curious why you would shut the engine down, just to operate the slides. In fact, I find my slide motors seem to work better when the engine is running.
