Question 2004 Pace Arrow 36B bad running 8.1 Vortec
The coil I bought was from AutoZone, Duralast brand ? Good or not ? I will take your advice and buy a spare, and of good quality for sure
Thanks
Not because I own a NAPA Store, but because I was a GM Service Manager for 30 + years. Autozone electronics are at the bottom of the barrel as far as quality goes. Oreilly 2nd line not much better, as well as NAPA Mileage Plus.
Sounds like you found the problem. My thoughts on replacing the coils is this. Many coils last well over 150000 miles without a hitch. If you are concerned buy one spare and put it in your junk drawer. Also buy a code reader so you can trouble shoot the problem code on the road. It is likely not going to be the same problem next time around. As @DHudson said, there is no saving buying cheap parts, NAPA sells quality parts, and can be found almost anywhere.
Thanks
Do you think it is better to buy AC Delco ? Or is NAPA just as good ?
Thanks
Thanks
AC Delco, Delphi, NAPA Echlin, Standard Ignition , NGK are all good
I've decided to buy a scan tool, I looked at one my neighbor has and it does not have the Workhorse chasis listed on the menu, I know it's a Chevrolet 496 engine as in the trucks, but will it make a difference in the scan tool function ?
Thanks
John
Thanks
John
OBD2 is fed required, it standardized the port and codes. Only special codes specific to manufactures may vary, and there are only a few, mostly to help trouble shoot. any code can be looked up online so it is not a big deal. Any OBD 2 reader will work for you,
Thanks for the help
Thanks
John
That is basically a Chevy P3500 or P4500 chassis. It "should" work with your vehicle, but can not be sure. I would call the scan manufacture and confirm for sure.
I have a fuel pressure gauge hooked up while driving, yesterday we went about 70 miles for a test, no issues on the way, stopped for about 1/2 hour and started back, in about 15 miles it went into limp mode, I pulled over and shut it down and decided to try it again immediately and it started and ran fine, no wait for cool down, tried this twice on the trip home, so apparantly the cool down does nothing, just switch off and on again and the problem stops ? During the whole trip the fuel pressure was between 60 and 64 PSI. I used a scan tool when the check engine light came on and it read weak signal to 02 sensor bank 1, that's the same code we got the last three times at the shop, and they changed out the 02 sensor to no avail. Any ideas ?
Thanks
John
I would not rule out an intake leak. Since only 1 bank is affected, I would start there. Those are known for intake plenum gasket leaks
A code for one bank wont be a MAF sensor as the MAF feeds both banks so...
Maybe change the intake plenum gaskets first , and see if that does it.
Post the code number EXACTLY as it appears . Plenty of O2 sensor codes ,they all mean something a little different
Also , there is a procedure to perform called a "Cam/crank sensor correlation relearn" procedure.
It wont run if there are active misfires happening
But , you will want to do this procedure if your coach has any miles on it at all.
I have seen 496 set misfire codes because of cam/crank correlation problems. Kind of a catch 22 there sorry
Post your code
Then probably on to the intake gasket.
If it has an intake leak , it is wacking the fuel trim ( adaptive strategy ) all over the place so....
This won't fix your O2 codes, but we used to get a lot of trucks that would go into limp mode with no codes. Just like yours, kill it and restart would run fine, sometimes for a month or more. Usually got worse and worse. Majority of the times, a NEW throttle body fixed it. If you got this route, do not be a rebuilt unit. You will be buying some else's problem. Only buy a new unit. And like before buy quality Delco, Delphi, Standard Ignition, NOE (Dorman) Napa, or TEE Napa.
I just saw the second code, both are as follows : PO131 02 sensor circuit low voltage Bank 1 sensor 1
PO151 o2 sensor circuit low voltage bank 2 sensor 1
Thanks
John
Since both banks are doing the same thing, it very well could be a MAF
Intake leak could be it also.
Maybe the MAF is dirty or contaminated.
You should look at the MAF to see if the little sensor inside ( thermistor) is covered with schmutz.
You can clean them with an artist paintbrush and brake cleaner by spraying it and GENTLY brushing it loose with the brush.Then spray again to rinse the sensor.
If it is dirty ( which is likely/possible) that would caus ea lean condition like you are seeing.
Any air leak in the intake /intake hoses after the sensor can also cause the issue.Look for holes in the air intake tubing.
You may want to change the intake gaskets just to rule it out. But check the MAF first.
If the intake is leaking, on one side, you will be getting too much air in those cylinders and the O2 sensors will get a faulty reading. If there is a plastic cover on the engine, remove it. Start the eng.jine and spray water from a spray bottle along the mating surfaces. If it start missing you have a leak. I always use carb cleaner will will speed up the idle. But hate to recommend that because of the possibility of fire.
But, I think you have 2 problems.
