- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
This will be my next pump substitution. Ive used the 3/4” retro kit when the correct ITR pumps were unavailable (total pain and will never do it again) and most recently replaced the summer loop pump with a current ITR item ($300 so that‘s beyond reasonable), so I’ll order one of these soon just to have it in stock. I don’t have experience with them yet but got this source from someone who had good results. The price is right and it has the right specs.
www.ussolarpumps.com
I can tell you from experience that anything with other than a 1/2” barbed fittin (or 12-13mm) isn’t worth the effort of retro-fitting. There is no extra room in the box for messing around with adapting hoses.
As for the $300 ITR pump, they seem to indicate that it is an improvement (don’t recall where I read that) over the original which for the price it should be. And the high failure rate is also really inexcusable. My unit is on its fourth replacement - every pump and zone one twice! Hopefully my new $300 summer loop pump will go the distance, but in the future I’ll use the $81 US Solar unit and take my chances.
hydronicheatingwarehouse.com
C1EA Oasis / Aqua Hot Summer Loop
The Aqua Hot Summer Loop Replacement Pump is an excellent choice as a replacement for many vehicles, boats and cooling systems for homes.
20010 OASIS CIRCULATION PUMP: ITR Brushless Pump 12 VDC 1/2 inch Connections
ITR Brushless Pump 12 VDC 1/2 inch Connections Newmar Oasis Stir Pump 103705T The mounting for the new pump is 2 1/4 in diameter 2 1/4 Bracket for pump is sold separately If replacing an older pump. All three pumps are the same.https://hydronichea...
