- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
Yep - its most likely a pump. If you change the fuse and it immediately pops the new one, you have a bad (stuck) pump. I bench tested a bad one, disassembled and reassembled it, and got it to run and then it started smoking and burned up. So just replace it.No heat in rear bedroom or rear bathroom. Oasis says zone fault for those areas. To late to go check for fuses so I'll do it tomorrow. But from what I'm reading, the fuses generally blow because the pump is shorted out or bound up. And from what I'm reading, changing the pumps is a real pita?
You can pay $295 for an OE pump, or try the US solar replacement pump (mentioned above) for a little under $81 - well worth trying a new one and it has @Buly’s endorsement. Thats what I’m going to do next time.
I’ve replaced all three of mine (one of them twice) so I should be good for a while. It’s not easy and its not exactly difficult - just kind of a pain getting in there, clamping the coolant lines, cutting off the factory clamps, etc.
One thing I definitely reccomend avoidnig is the retro-fit kit with 3/4” fittings. It’s cheaper, and availability is better, but it is not worth the hassle of making it fit. I did it because there was nothing else available from Oasis/ITR/Hydronic warehouse at the time, and I didn't know about the US Solar pumps. But it was a shoehorn fit and not fun at all - never again!
Factory pump:
20010 OASIS CIRCULATION PUMP: ITR Brushless Pump 12 VDC 1/2 inch Connections
ITR Brushless Pump 12 VDC 1/2 inch Connections Newmar Oasis Stir Pump 103705T The mounting for the new pump is 2 1/4 in diameter 2 1/4 Bracket for pump is sold separately If replacing an older pump. All three pumps are the same.https://hydronichea...
C1EA Oasis / Aqua Hot Summer Loop
The Aqua Hot Summer Loop Replacement Pump is an excellent choice as a replacement for many vehicles, boats and cooling systems for homes.
Buehler C20 Pump Retro Fit Kit 400/450 - PLE-100-905-FRU
Technical Service Bulletin 450-400 Pump Retrofit PDF Document BUEHLER C21 400 - 450 Pump Retro Fit Kit. New Style Pumps are used on all new aqua-hot and hydro-hot systems. This can be used as a circulation pump, stir pump & engine pre-heat pump. *...
On your other heat sources, you have heat pumps, not just air conditioners, so you need to find that selection on your thermostat. Mine is simple, but yours may not be. So when plugged in or on the genny you will generally use your heat pumps; when “unplugged” you’ll use the Oasis. You may very well have heated floors too. You really need your MSRP and build sheets, available from Newmar - they’ll email them to you.
