Kevin D Pem
RVF 5K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Picture explains all. I included one of front air dam.Are you talking about a straight pipe under the MH, or exiting out the side of MH
Absolutely out the side as exiting underneath the coach would allow for dangerous gasses to enter inside. Illegal in most states.Just wanted clarification as one way isn't safe at all.
I'm back, I want to just add to what I have done to my ford V10. I cleaned up my cold air intake and added a K&N large cone intake filter. Was planing to change out the ford stock catalytic converter to a legal high flow converter like I did on my last rig. But I researched what the flow restriction was on them, To my surprise the restriction on the stock unit is 1.5 to 2 PSI at full throttle. Not much difference with the performance cats, so I am staying with the stock unit..I am now waiting for my performance muffler to come. When the new mufflerThat was one of my goals - to reduce the constant down shifting and make it pull a little longer on a higher gear on grades. With 5 star, Banks, and a free-flow intake (forget which one) I made some real progress, but when running full throttle up a hill the intake was loud.
Seriously ? How much of an improvement are you expecting looking for ? Just askingI get 6 MPG with my 34 foot rig with the V10. What can I do to improve the gas millage? It is a Thor Hurricane.
If you consider noise an improvement then go for it.I'm back, I want to just add to what I have done to my ford V10. I cleaned up my cold air intake and added a K&N large cone intake filter. Was planing to change out the ford stock catalytic converter to a legal high flow converter like I did on my last rig. But I researched what the flow restriction was on them, To my surprise the restriction on the stock unit is 1.5 to 2 PSI at full throttle. Not much difference with the performance cats, so I am staying with the stock unit..I am now waiting for my performance muffler to come. When the new muffler
comes in from Summit, I will change out the stock muffler for the high performance muffler. Can't wait to hit the road to see what kind of improvement I get..
We have a 31' Phantom, between 7 & 8 mpg. Pull a light trailer with a motorcycle trike. MPG will vary depending on speed. 70 mph will decrease from less than 65.I get 6 MPG with my 34 foot rig with the V10. What can I do to improve the gas millage? It is a Thor Hurricane.
What speed are you traveling at? I hace a 23 37 foot Windsport with the 7.3L gas and get 8.5 at 63 MPHI get 6 MPG with my 34 foot rig with the V10. What can I do to improve the gas millage? It is a Thor Hurricane.
That’s awesome!What speed are you traveling at? I hace a 23 37 foot Windsport with the 7.3L gas and get 8.5 at 63 MPH
