TXheat
RVF VIP
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
We recently got this RV and for the most part the shore power system works fine, the entry steps work fine on 12 volt when not connected to shore power the 12 volt lights do not function the control panel does not function. One of these strangers symptoms is that when connected to shore power it appears that the batteries are not getting enough charge although the control panel shows around 11 something. These batteries are fairly new but they may not have been connected properly. There are four six volt batteries in series, when connected to shore power the refrigerator functions the water pump functions the switch to the propane valve does not light up nor do any of the other 12 volt switches the battery cutoff switch is not off this is a real head scratcher. If anyone can put me on the right track to finding a solution and greatly appreciate it attaching photos in case they help, thanks
