- Jan 19, 2021
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
First, and most importantly, Im only getting hot water when one of the heating zones is on. Doesnt matter if the heat is coming from the burner or electrical. My guess is its a pump, which of correct, couple only be the “summer loop” pump because both zones work, but as I said - its a guess.
I am still a rookie with this system. I have replaced the zone 1 pump with the 3/4” retro kit available last year during the initial pump shortage, so no problem fixing this IF thats the problem, although from recent comments, it appears the pump shortage is still on, and I dont want to adapt a different pump again. It worked but wasnt easy and there just isnt enough room in there for more hose adapters.
Second, for anyone who does their own Oasis maintenance, I’d like to know the source you use for the maintenance kits, any tips for making the job as easy and successful as possible, and any “watch outs” to be aware of.
Thanks in advance,
Rich
Thanks in advance,
Rich
