Battery not charging on shore power
aundray10
Minnesota
Fleetwood
Providence 40E
2014 Jeep Wrangler Unlimited
I recently did some work on my generator and while hooking the 12v cables back up inadvertently reversed the cables and shorted it out causing damage to the battery disconnect solenoid as well as the aux start solenoid in addition to blowing a couple fuses in the Battery control center. Now I have replaced both of the damaged solenoids as well as the blown fuses, but the aux start is not functioning and the chassis batteries are no longer charging when plugged into shore power. Cannot locate the BIRD to check it. Any help would be greatly appreciated.
