- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
Can I just say Hallelujah! Newmar is done with KIB. As many of you know, I, as many others, have had issues with my black tank sensors reading properly from year 1. I've had new sensors, water pump relocated, new board, software updates, tons of recalibrations to no avail. This past visit to Newmar has taken care of my problem. Newmar unplugged the KIB pad on the tank and installed a a sensor by the gate valve that works by pressure (gravity). The higher the water level, the more pressure you have. It is working so far. No red lights, no showing 100% full when empty. It's the little things! Oh and the floater is still in the tank, so IF you do get a full tank reading when you think it's not full, you can pull the famous yellow wire and if it is still red, you know you are full. ?
