Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
I've never even thought of that before and both my water tank and fuel tank are up front. 100 gallons water full and 130 gallons of diesel full when I leave. I just took for granted it was engineered to handle it.One thing I would caution about is how much the water tanks adds weight your coach. You do not want to be over the weight limit, particularly on your steer axle. Just be aware of it if you have not done a four-corner weigh.
Did the nexlink work for you? Code gone? How do you know when your coach is doing a regen? Newmar did one last year as part of maintenance for us.Yes, my coach does regens automatically, how often I can not say I never kept notes on it but if I'm on a 3 month trip moving around every week I bet I see 3 or 4 regens. It might be less if I run in 5 gear. Spartan recommends that to get the temp up when running down the highway at 65MPH. In 6 gear I'm at about 1,700 RPM and 5 gear about 1,900+. I did get the Nexlink tool so I will try that and see if the code goes away.
I know you are trying to make connections here with high altitude, but the problem in my case my coach was doing a regen when I had to come to a stop and then it tried to continue the regen, but after I had the stop, I started throwing codes. It tried to continue regen when I got up to speed and then I stopped to park at the CG in Santa Fe. The last thing you want to do is go from hot and turn the coach off. I ended up with soot getting stuck in the intake valve. If you do decide to do forced regen, you want to let the coach idle for about 10 mins so the temperature can come down before turning it off. If you shut it down while hot, you will probably throw codes.As I mentioned @ARD had hers after Angel Fire (8000+ altitude) and it happened traveling in high altitude ops from Angel Fire to Santa Fe to ABQ.
I found that very true on my 3412. The sweet spot is 80% water, empty blk & gry tanks and start off full fuel of course. Better ride and more stable in wind/passing. When I get down to half a tank of fuel I can tell the handling is starting to change. And towing a 4400 lb jeep.I Attended the Freightliner camp, and the lecturer recommended to travel with full fresh water tank for a better ride?
