It is a pain to plug and unplug appliances from the plug under the kitchen cabinet. Has anyone found a good solution to extend the plugs and attach them to the back or side wall? If you have to you have a link to what you used.
I know this is a little bit of work but I installed a drop down receptacle and that solved the problem. When not in use it pushes up flush with the bottom cabinet.
Here is what I use to shut down power at any 110 outlet including our Girard awnings. Originally used a switch at each awning but this required opening the compartment to access the switches. These are controlled from my phone and work great besides being cheap.
