Fresh Water Storage Tank Leaking
Texas Clodhopper
Garden Ridge, TX
Ventana 4369
Longer daily
Freightliner
Cummins
2022 GMC Canyon AT4
I filled my fresh water storage tank a couple of days ago using the auto-fill method. Once full, of course, it started running out the tank overflow. I set the inside auto fill control to off but apparently, it didn't turn the valve off since water continued to flow until I turned the park supply off. I know about the overflow drain being too low being problematic and I replumbed that some time ago. I'm running currently just the pump because if I turn the park water on it fills the tank and here I go again. Any suggestions?
Thanks.
2017 Ventana 4369
See if this is your scenario:
Let me ask the glaringly obvious question: Is the valve in your wet bay set to auto fill?
Lol...yes, the valve is set to auto fill and the inside switch is set to off. I'm sure it's that solenoid valve stuck open and I'll wait until I'm home to tackle removing the hose reel. Thanks for all the suggestions.
Apparently whatever gremlin was causing my issue moved out. The only thing I did today was move the water valve from manual fill to automatic fill several times so maybe a foreign object was stuck inside the valve.
