- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Strange. It’s a steel C-channel and custom bracket. I guess I just assumed Newmar had a CNC or Laser cutting machine and cut the brackets from that. The C-channel could be cut to length by any well equipped metal fabricator.
Newmar factory/service center has the raw materials there for custom fabrication, but not CNC or laser cutting. They use the typical saw/grinder method to cut the raw materials, and send it off to the paint shop to get sanded and painted. They will only do this for parts that the tech measures and cuts himself. Going to the factory, you get a custom, one-off fix.
The parts being shipped to dealers will go thru the entire product development life cycle. Engineering will use CAD to design it, and a vendor will supply it with mounting holes cut, and powder coating applied. They will be laser cut, mass produced, and all the same. At that time a part number will be generated, and distribution can begin.
We saw the same thing with the sanicon fix. The service department developed them and made the brackets. They tried to get a part number assigned, but engineering decided to change the entire setup and get rid of the sanicon 500/600. In doing that, they also made the decision that owners with the incorrect sanicon bracket where unable to get one made unless they scheduled a factory visit. No dealer was able to order the bracket, and my attempt to order direct from service also failed. I was there when @ARD had hers custom made, but I didn't want to add an extra week to have one custom made.
This issue is structural, and will be handled different than sanicon. Engineering will have to complete the PD phase and create a part number.
