I just acquired a 2011 Laredo 310RE that I haven't even used yet. I need to get it winterized but the steps I found online are not matching up with what I have.
I found the drain plug in the water heater but I cannot get it out. It's either rusted in or someone welded it. I did open the pressure release valve and some water came out of it. I looked for the bypass valve and it is no where to be found.
I have crawled under every inch of the camper and there are zero drain plugs hanging down. On YouTube Keystone shows a red and a blue line directly under the tanks. I did find one white plastic tube with a cap and it is located directly behind the wheels on the door entry side which would be the passenger side of the tow vehicle. I removed it and not a drop came out. If this is the drain line, is it the only one?
