Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
Another important consideration and one of the reasons I have held off converting my coach to lithium batteries.Also to be considered… how long to you expect to keep your Ventessex?
If not so long, maybe less AH or get AGM…
At this moment in time I'm keeping it for the long haul. Hence why I replaced TV's and ran upgraded wires, etc. in that this coach is perfect for me. With Newmar's price hikes and quality issues among the economy etc. I don't see a new coach in the near term. My next coach would likely be luxury line such as MA or LA but it would need to be on a FL chassis (let's not go there) but that's my requirement. With that said my mindset is to continue to make my current coach amazing, to me, and keep going the places it takes me. I do have a desire to disconnect (go off grid) and approach near full timing, if not full timing completely but also continue to learn. Much of what I've done in this coach has been about learning including solar so the LifePO4's would go under that learning theme. I wouldn't mind reducing weight and improving storage by taking better advantage of the battery compartment.Also to be considered… how long to you expect to keep your Ventessex?
I still want your old tray if you still have it - just havent made it out your way yet, but maybe in 2023. You’re not that far from a lot of famoly and now my daughter and 3 or 4 of the GKs might be headed to Mooresville.True… my main reason to remove the tray was so I could properly insulate the compartment…. But your alternatives would work too.
