Texas Clodhopper
- Nov 16, 2019
- Garden Ridge, TX
- Ventana 4369
- Longer daily
- Freightliner
- Cummins
- 2025 Jeep Gladiator
Agreed! We need a "GFCI Central" here on RVF. If everyone would post in the same format, it could be a great database.GFCI comes up far too often and I'm clueless where the reset(s) is/are. We really need to identify these for our coaches to pin them down once and for all.
i have no power to the washer or dryer. Breakers are ok and unless there is a GFIC I haven't found yet everything seems to be okay.
Any suggestions?
2017 Ventana 4369
Thanks.
Stop the press for an update. The problem was the power cord connector that plugs in to the Progressive EMS was oxidized. I cleaned the blades with a little sand paper and applied some dielectric grease - problem solved.
Thanks for the update. Very interesting resolution. I'm wondering if it was a combination of oxidation on your plug and also in the power post receptacle. Maybe cleaning one cleared enough resistance to allow current to flow. I've found quite a few power post receptacles over the years that were in poor condition and created connection problems. They take a lot of abuse from the constant plugging/unplugging cycles (sometimes under power when someone forgets to flip the breaker off).Stop the press for an update. The problem was the power cord connector that plugs in to the Progressive EMS was oxidized. I cleaned the blades with a little sand paper and applied some dielectric grease - problem solved.
I missed the fact that you were plugged into the PI unit. I think that when you cleaned the connector contacts on your power cord, you solved the problem. The socket on the PI unit doesn't usually take much abuse, so I'm guessing it is OK.TJ, it was interesting, when I plugged the shore power cord into the pedestal I had power, it was only when I plugged in to the portable Progressive that I didn't. It could be the female plug on the Progressive was the culprit and the plugging and unplugging I did cleaned it up.
