- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Is your warranty period still active? I thought it was only for 3 years. Perhaps you got your coach late in the model year. Mine expired 6 months ago.This should all be under warranty AFAIK. If not, I’ll drag out the checkbook.
You should be able to access the fault code on the Spartan message bar and on the Silverleaf console display. I believe it’s available under the chassis screens. Recently I had my ACC disabled due to an ABS wheel sensor issue which was easily resolved.The ”check engine“ light is now on and the regular cruise control is disabled.
Are you talking about the “RV-C diagnostic codes?” If so, it says “No Faults” but I still have a Check Engine light showing.Is your warranty period still active? I thought it was only for 3 years. Perhaps you got your coach late in the model year. Mine expired 6 months ago.
My understanding is that the Spartan warranty is 3 years unless it’s emissions related in which case it’s 5 years.We took delivery on July1, 2018. I‘ve been told that ours was the last 2018 Mountain Aire to roll off the line; the next one was a 2019. That would just get us just inside the 3-y,ear window, If it is a Spartan issue, isn’t it a 5-year coverage?
I think you are right. That said, I just verified that our purchase date was 6/30/2018 so we should still be good…by about two weeks.My understanding is that the Spartan warranty is 3 years unless it’s emissions related in which case it’s 5 years.
Not necessarily. I’ve had my check engine light come in when the anti-lock brake system had a fault due to a dirty wheel speed sensor. Where you able to access the fault code?I would assume the “check engine” light would indicate that the problem is somehow engine related.
No. It says there are no faults…but, the check engine light is on. I’m going to have the Cummins folks walk me through that process in case I’m doing something wrong.Where you able to access the fault code?
Glad you’re back on the road. Sorry for the bad experience. Keeping my fingers and toes crossed for you that it’s smooth sailing from here on out - minus the Girard sails.On the road again. The check engine light went out on it’s own, but we stopped at Cummins anyway. The fault codes were almost all cruise control related. One old “air filter flow restriction” code but we had a new filter installed in May so the tech just reset it.
They weren’t interested in trying to find the engine shut-off issue. If it happens again, I will just put it out of it’s misery with the .40
S&W. ?
Frankly, other than the tech that checked the codes, our visit to Cummins was underwhelming! It seemed like they don’t like to work on motorhomes. The guys at the service counter were abrasive and surly. I sure didn’t feel welcome there.
Oh well, we are back on the road with LadyDi at the helm. That’s a good thing.
