Rustymayes
RVF VIP
- Sep 11, 2022
- Vacaville, CA
This weekend I was using the furnace to heat the coach while out Glamping on the Russian river. Over night temps already getting into low 30s!
I had the burner on and both AC elements and realized that the coach stopped heating up. I had the floor heat on as well which kept the core temp up a bit and I realized also that when I ran the aqua miser for the shower that the red light was not lighting. I shut off the furnace heat and the water did heat on the electric but not enough to warm the coach and have shower hot water.
I noticed the heater module led lit so checked the Oasis front panel and the module panel on the bay wall and saw no red LEDs. There were several green ones not lit. I hit the reset button on the unit and that cleared the fault light but it came back as soon as I selected the burner again. Any ideas on what to look for. I am suspecting the igniter? that green light was blinking green after reset with burner selected. I will cycle the salesman switch just for grins not that I am back home and before I power up the coach on my 50 AMP supply.
Thanks for any insight.
