Jim
- Dec 18, 2019
- North Carolina
- London Aire 4551
- Freightliner
- Cummins / I6 Diesel Pusher 600HP / 1,950 ft-lbs
- 2016 Jeep Rubicon
I've been at this park now for about 2.5 weeks and haven't had any problems with the power. But last night abut 5:30pm, the generator suddenly came on. It's set to exercise at 1:00 on Monday's, so I knew that wasn't what it was doing. At first, I thought I had a real problem, but I noticed the Silverleaf was showing -0- AC coming into the coach and I realized the autogen had started to run the air and keep the temp at the set temps.
Checked the breaker at the pedestal and sure enough, it had tripped. I reset it but it tripped again a bit later. I went to the main office but no help until the next morning. They changed the 50amp breaker to a 60amp breaker, and that seemed to fix the issue. But a little while ago it happened again.
I don't know if the park has an issue or if my coach is an energy hog. All 3 of the air conditioners were running, the Oasis is heating water with the elements, and Trish had the dryer running. Am I the problem here? I've turned off 1 of the air conditioners and nixed the dryer until tomorrow morning when it's cool outside. Haven't had a problem since that.
Autoformer reports all green lights, so I'm thinking my coach may be a bit of an energy glutton?
