CaptainGizmo
RVF Expert
- Nov 3, 2019
- Newell
- 2020P
- 2017 Ford F-150 Raptor w/AF1 Braking
Thanks. I was able to use my company provided hot spot to go to the 'net and pull up an owners manual. It's pretty technical but I understood most of it. I didn't see anything that would help. Thanks again for this!Sounds like you haven’t downloaded the manual. I just did a Find on mine and have this for you…
The AT&T SIM actually worked for a week with nothing in the APN box. We used 40G of the 100G this way. The moroons at the AT&T store told me to use NEXTGENPHONE for the APN but it would never boot up with that in there so I left it blank and it worked. The T-Mobile SIM pulled up the correct APN on it's own.fast.t-mobile.com would not, should not, could not work for your AT&T card. It would work for your T-Mobile card. I wager that’s why your modem kept selecting T-Mobile. It couldn’t get through on AT&T because that APN would not work for it.
change it to broadband and see if your AT&T card lights up
Yeah, I did a reset to factory settings after working on this stupid thing for over 2 hours. I thought maybe I had inadvertantly hit a button by mistake. It didn't help. The Peplink still would not recognize either card AT ALL. The boxes were totally blank most of the time last night.I had a lot of intermittent connection issues when I first got my max duo set up with 2 sims, I wound up factory resetting the router, and it has not given me any issues since. Have you tried a factory reset of the router?
The moroons at the AT&T store told me…
Where is the spot to change it so the carrier only uses LTE? I haven't seen that one yet. Is it on the details page? Thanks!When you get the SIMs detected you can set the carrier to use LTE only and not use auto which is what I do so you won't get 3G.
There is a symbol near the sim slots in white which shows the SIM card orientation.
You can contact peplink or your vendor you bought from and get tech support. You can also try factory resetting the unit. Download your config first if you want. If you can get Internet you can check for firmware updates. If you go to the /support.cgi page (manually typed in browser) you can check for cellular modem updates.
