Michael T Klukas
- Aug 10, 2024
- Florida
- Coachman Freelander 22 XG
- Ford E350
- My Bicycle
Depends on the output of the source. Most cigarette lighter sockets for example supply 5 mA or about half of what you want. Is the device specifically rated to be used without a step down converter (wall wort)? Use a multi-meter to test your 12v source. Once you find an appropriate source, add a 1 amp in-line fuse for protection
Yes it uses a A/C adapter plugged into 110. After cutting the wires I should test the wall adapter. My understanding so far is the 12 volts need to stay the same, but the amps need to be 1 amp or higher. You are also saying I should add a 1-amp fuse to the wire. should I place the fuse on the + or - side?Depends on the output of the source. Most cigarette lighter sockets for example supply 5 mA or about half of what you want. Is the device specifically rated to be used without a step down converter (wall wort)? Use a multi-meter to test your 12v source. Once you find an appropriate source, add a 1 amp in-line fuse for protection.
I understand to keep the Volts withing the Acceptible range or at the 12 volts. If I need the DC to DC, would this work: Amazon.comYour power brick likely puts out 12VDC while the vehicle voltage will vary from say 11V-14V depending on whether you are pull power from house or chassis and whether charging is taking place. You need to ensure that the device being powered is capable of such a range and if not use a DC-DC voltage regulator to get the desired 12VDC.
I purchased a clamp meter with A/C D/C. I think this will allow me to determine that. Thank you!Most of my cigarette lighter female plugs support 12 volts on a 10 amp fuse protected circuit. Your one amp device will typically be no problem. Your slight problem will be trying to determine which wires are positive and negative.
Rick
Thank you, Kevin, I think I got it handled. The manufacture replied that it is 12volt 1 amp and is now checking on the Voltage range but believe the product was designed for a 12 volt range that would work on an automobile battery setup so I should be ok. I may buy the DC-DC inexpensive converters anyway because they are cool, and I would like to experiment with them on other projects. By the way I used some of your advice on the solar decisions, so thank you for that.What device are you trying to power?
Then I will answer your question.
That would work. I've also purchased these and these, but I prefer this one for mounting.I understand to keep the Volts withing the Acceptible range or at the 12 volts. If I need the DC to DC, would this work: Amazon.com
I would just need to figure a way to mount the DC to DC. That should not be a problem.
Thank you!
Thanks, I will give them a look!
Little story. I just changed my system voltage. I took my Lithium 48 volt battery out of the mix. This required changing the voltage on everything! I am back to a 24 volt system, and am much happier, but, I only have one 12 volt load and forgot to account for it! Short story long, I was having trouble figuring why my water pump became so louder than it was. I have been thinking it was on it's way out, I started checking things out! Come to find out it has been running on 24 volts for about a month.Thank you, Kevin, I think I got it handled. The manufacture replied that it is 12volt 1 amp and is now checking on the Voltage range but believe the product was designed for a 12 volt range that would work on an automobile battery setup so I should be ok. I may buy the DC-DC inexpensive converters anyway because they are cool, and I would like to experiment with them on other projects. By the way I used some of your advice on the solar decisions, so thank you for that.
Fuse on the live power side. It might not be needed as many 12v devices have built in over charge protection, just consider it as insuranceYes it uses a A/C adapter plugged into 110. After cutting the wires I should test the wall adapter. My understanding so far is the 12 volts need to stay the same, but the amps need to be 1 amp or higher. You are also saying I should add a 1-amp fuse to the wire. should I place the fuse on the + or - side?
