Share your Starlink RV install and experiences
lemondrop9344 and marc2912 ,​
Thank you very much! My problem is that much of what you're saying is going right over my head. I understand that a direct wire from the dish to the starlink router placed inside the coach is the best solution. However, that's going to require me to have Newell install an adapter from outside the coach, into the coach, from which I can plug in the router. Newell seals there coaches pretty completely, and I'd like to avoid breaking that seal. But yes, that can be done, and is likely the way to get the strongest signal inside the coach.
However, I am already ordering a mesh for use at my casita in Arizona, where we stay for 3 winter months. So if I have the mesh, why not use it in the coach, rather than installing an adapter to bring the cable inside? Is there any downside to this or reason it won't work? I'll have the wired SL router in the forward driver side basement, (for several reasons not worth wasting your time explaining, that is the best bay for the router). There is a great spot inside the coach, just behind the driver's chair, to place the mesh. That gives the mesh a straight unobstructed shot to the back of the coach. And if "overkill" is the answer, what's the downside, if I already own the mesh?
Thank you again!! Ed
Short answer........ if you already have the mesh device & plan on using it in both locations, there is no downside.
My biggest gripe with Starlink is their proprietary connector from their DISHY to their router. IMO, it makes connecting the DISHY to the Starlink router less than user friendly without cutting & splicing the provided Stalink cables.
As I read your response, it leads me to believe you do not yet have the Starlink equipment. I will assume you are getting the Gen 2 Starlink setup. As indicated above, the Starlink proprietary connector & cable does not easily lend itself to a clean installation in a RV. The proprietary connections are on both the DISHY & the Starlink router & require a larger hole than regular Ethernet wiring. One way or another, without running cables through a window opening, or an existing wiring run, you will need to attach the DISHY to the Starlink router. Most likely it will be with the proprietary Starlink connections. A caveat follows:
There are all sorts of methods to circumvent this described on the internet. Most involve some sort of modification to the supplied Starlink cable between the DISHY & the Starlink router. If it's discovered by Starlink you have done this, it voids your warranty.
You will also require a Starlink Ethernet adapter to attach your mesh device to the Starlink router.
Please understand, I'm not trying to discourage you from your proposed method of setting up Starlink in your RV. I'm just trying to ensure you are aware of all the pieces you need to set it up as you have described.
Good luck & safe travels.
@ehochuli85 all you can do now is try the mesh router. Yeah, some of the discussion above got pretty deep and beyond the scope of your question. I'd reach out to Newell at some time and just ask them "if I had you run an ethernet cable from the basement inside the coach, where would you do it and is there already an conduit in place that I could use to run it myself?" - there is a chance they preinstalled a conduit and some Newmar owners will "special" this for this very reason.
There are other ways to do this directly with a Newell’s coach network and router.
As you'll see from one our test setups below...⬇︎
I think I'm really going to regret this post..... If you want to loose the portability of your StarLink Dishy and have it permanently attached to your coach, I have done that and it works well. In my case I mounted the dish on the roof just behind the spoiler on my Newell and ran the cable down to the upper electronics bay where I added a PoE injector and plugged the dish directly into the factory supplied Cradlepoint router. This eliminated the Goofy shaped SL router and simplifies my Wireless setup. I also run a T-Mobile home gateway into the Router for alternate ISP Service if the SL Dish is blocked or speeds on TMO are faster. This is my setup and I think it works best for me.
Thought I would make an update, I finally got out of the "starlink cable through the window" mode. I looked in the master bedroom cabinets and found a cat6 cable labeled satelite, toned it and found it in the basement. I cut it, put a cat6 jack on one side and cat6 plug on the other, so I did not ruin future use of the cable as it was intended to be used. For my purposes though, I plugged the cat6 plug into the starlink adapter and router now moved to the basement, the other end into the wan port of my pepwave max duo mounted in the area where the bedroom tv used to be. Accomplished what I wanted which was a cat6 cable up in the bedroom in the TV compartment but without having to run new cables in to and through the full wall slide mechanism. Using my existing ubiquiti router fed from the pepwave lan port for wife to plug ethernet into and for wifi in the coach, and all working well. Happy to not have the cable through the bedroom window anymore!
Marc2912,
Every configuration presents unique opportunities based on physical limitations, the equipment available & the user's needs.
You posed the following question in a previous post; 'Why would you not wire your starlink to the peplink?'
Not withstanding the hassle of running Ethernet cable & using the proprietary Starlink Ethernet adapter, the simple response, in my case.............. what will I gain by hard wiring the Starlink router to my Peplink router?
I just ran an Advanced Starlink speed test. Results are posted below.
Starlink satellite to Starlink router Download speed: 253 Mbps Upload speed 25 Mbps.
Starlink router to Android phone WiFi Download speed 566 Mbps Upload speed 469 Mbps
In so far as my router has a superior processor & antennas over my 4 year old phone, I would assume the WiFi signal from the Starlink router to the Peplink router would be as robust if not better.
I believe we all agree the weakest link in most Starlink installations will be the signal from the satellite to the DISHY/router.
In my example, I'm attempting to show there may be situations where Ethernet wiring of Starlink components will not necessarily be worth the hassle involved.
Your test results baffle me a little but I am half way through second cup of coffee and will re-read after complete :)
I know with one other there was a difference between and old iPhone between phone and router and far better speeds with a Wi-Fi connection from Pepwave with Wi-Fi 6 and Starlink router. No cables, but the Wi-Fi 6 I believe made the difference and I even believe distance was further.
So again, help me with your example and what you're showing and how Wi-Fi vs. Ethernet is proven different as I can't understand the sample case.
But again, Wi-Fi 6 (or better) I believe is a key for better transfer rates for non cabled connections.
Neal,
I put forth this example to demonstrate that one did not necessarily require an Ethernet connection from the Starlink router to, in my case a Peplink router, attain a robust signal inside a RV LAN. This was in response to Marc2912's question wondering why I would not want a hard wired connection from the Starlink router.
As it relates to WiFi 6........... I don't know if the Starlink router does or does not take advantage of this technology. I am using an older phone with a Snapdragon 835 chip, rated @ 1GB theoretical xfer speed. To the best of my knowledge it does not have WiFi 6 capability. I assume WiFi 6 functionality does not come into play until the signal is routed through the Peplink device.
Using the Android Starlink app, I went to the Starlink advanced speed test. If I understand what it is showing...... It reflects Download/Upload speeds from the Starlink satellite to the Starlink router & the Download/Upload speeds from the Starlink router to the Android phone (not the Peplink router).
Based on these results (I've run this test multiple times), it suggests my Android phone processes the WiFi signal from the Starlink router at least as twice as fast as the Starlink router can receive the signal from the satellite. Assuming my interpretation of the speed test data is correct, I question what signal improvement I would gain by hardwiring the Starlink router to my Peplink router.
I am still in the 'run the Starlink cable from the DISHY to the Starlink router mode'. For the time being this is a conscious decision.
I have the Starlink router around 6' - 7' away from my Peplink device using paddle antennas.
For the record, I am a big time advocate of hard wiring as many devices as possible on a LAN. However, running Ethernet cable in a RV can sometimes be more difficult than running cable in a S&B residence. If a LAN WiFi connection is performing as well or better than the incoming signal (in this case from the satellite to the Starlink router) why would I want to go through the hassle of running cable?
A lot of words on my part attempting to clarify my thought process on this. If I have interpreted the data incorrectly, it will certainly not hurt me feelings to have someone correct me.
Hi lemondrop, it has been covered more extensively elsewhere but there are known issues with SOME peplink products with using wifi as wan and wifi to devices. It involves channel collisions (in on 2.4 and out on 2.4, ditto on 5) and has not been fixed by peplink. Unfortunately after spending a lot of money (my perspective) on a peplink max duo, I have found I am one of the unlucky ones with this specific problem. Since I cant hard wire everything in the RV for the exact reasons you mention, if I hard wire the wan from starlink to pepwave I can use wifi elsewhere with no issues. Bottom line, if your device supports wifi on wan properly, you are correct there is probably little benefit to hard wiring and most would never be able to tell the difference in service quality. Unfortunately my option was to flush the money I had already invested in peplink equipment and replace it, or find a way to make it work. My post just above explains how I currently set up and now have solid wifi, load balancing on 3 ISP providers with emergency backup and a happy wife who is still working full time from the RV. Hope that helps explain why some of us have to have the ethernet to make this work. For the rest of you that dont need it, Im jealous!!:giggle:
Scotttkd2,
Understand what you are saying.
I have not experienced any WiFi as WAN issues with Starlink or with the RV park WiFi when routed through my Peplink device (Max BR1 PRO LTEA)..... that I know of.
Signals out of the Peplink are hardwired with the exception of the multiple ROKU devices.
Latest responses were more or less to respond to questions from Neal & Marc2912.
We have the issue scottkd2 mentioned in our Pepwave Transit Duo Max — cannot reliably use a WiFi band for both input and output.
So I use 2.4 for input (reach further to campground WiFi when available and Starlink) and our devices all connect to Pepwave on the 5.8
I was attempting the install with a home version we are using for out home office. I tried to set it up at my RV about 15 miles away. See my post about it not working.
Home version unless roaming service is registered to location.
Thanks again, Neal and Scottkd2, for the great on-point info.
On the theft issue, someone told me that the Starlink is like an iPad, in that if it gets stolen, you can deactivate it / report the theft to Starlink, and no one else will be able to use it, even with their own account. If so, that removes a lot of the motivation to the thief. Anyone know if this is true?
I suspected that to be true from above post about used dish.
Most people that have used sat tv know the dish to be useless without the box,but???
Ran across this video. Interesting.
I watched the video! I watched it twice, matter of fact. I saw numbers, but no personal data. Fact is I tried to hear her say she ever took delivery! Did anyone else notice that?
This is my view of starlink!!!
If I didn't have it, I would not even have phone service, that is how bad cell service is most of the places I go. And yes, I have tried many cell companies. At&t, Verizon, t-mobile, and Sprint before the merge.
I asked real people that actually were using starlink for their view and opinions before I took the plunge, but more than that, I read everything on the website as well. Service can drop as low as is not the same as will drop to, as said in the video.
Guess I can see motive when I see it!!! I used to watch her videos, but now I know why I no longer do!
Just saying.
