Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
These recommendations make sense and my Magnum devices are above recommended levels and I have not had any issues with charging my Lithiums. I am using the ARC50.
And each manufacturer has their own recommendation. Here is what Battelborn told me:
To set for lithium battery charging in a 12VDC system:
- Press the SETUP button;
- Turn SELECT knob to 03 Charger Setup, Press the Select knob;
- Rotate to 03C Battery Type, press Select knob;
- Rotate to Custom, press Select knob;
- Absorb volts = 14.4VDC;
- Float volts = 13.2VDC;
- EQ volts = 14.4VDC;
- EQ Done Time = 0.1hrs
- Rotate to 03D Absorb Done Time, press select knob;
- BattleBorn wants this set for 0.5hrs per parallel battery string, if you have 8 12V batteries then this would be 4hrs.
- Rotate to 03G, press Select knob;
- Rotate to Silent, press Select knob;
- ReBulk volts = 13.2VDC
