- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Starlink offers an ethernet adapter on their store which if you can run a cable connection to your router, such as my Pepwave, to Starlink, this is an ideal way to access your Starlink Internet. My concern is all of the Wi-Fi noise by having multiple routers in your RV such as for my I use a Pepwave BR1 Pro 5G and now Starlink adds its own Wi-Fi router to the mix. Another reason you want to get Wi-Fi 6 devices if you can which both the Pepwave and Starlink routers use and connect with the 5 Ghz Wi-Fi instead of 2.4 if using Wi-Fi when able. Starlink offers an option in the settings to separate 2.4 and 5 Ghz networks but I haven't messed with that (yet).
When I first setup my Starlink with a cable (ethernet) connection to the WAN port of my Pepwave router all worked fine but stowing the Starlink was hit or miss much less the app unstowing option showing once stowed. When I got things setup with the Ethernet connection I used the option in the Starlink app to disable the Wi-Fi to minimize the noise as mentioned above. I was having some connectivity issues which later I determined to have nothing to do with the router but I reset the router to get Wi-Fi back and this is done by unplugging and replugging the power connection into the base of the router. I initially did this by pulling the plug from the outlet 3-4 times and amazingly that did not reset it when actually doing this from the plug into the router did.
Since resetting my router a few weeks ago I left Wi-Fi on and did not disable it. For whatever reason, even with the ethernet connection to my Pepwave which is the only way I connect to Starlink, the Starlink app works much better communicating with the router. Maybe it's a bug in the router that just doesn't like having it's Wi-Fi radio(s) turned off, but it is what it is. Again, I only connect to Starlink via the Pepwave WAN connection, my phone is Wi-Fi connected to the Pepwave and not Starlink and the app works much better - as it is expected to work.
So the moral of the story is from what I've observed, even if using the cable connection, which I recommend over Wi-Fi connections any day, don't disable Starlink's Wi-Fi radio which is an option in the app. Maybe it will work better for others but since leaving it ON after being reset I haven't had any issues stowing or unstowing the dishy.
