Tire pressure monitors
I got a surprise today. My TPMS showed a day early! USPS even!!! Anyhow, after I made sure all the tires had the pressure I wanted the rest was really easy. All I did was put a battery in a sensor, screw it on and within seconds BEEP. It recognized it for where it was and gave me the pressure and temperature. On to the rest. It also had a trailer disconnect function so I won't have it hollering at me about not seeing the trailer sensors. This TPMS even came with a booster to hook up so that the trailer sensors get seen going down the road. The only thing I didn't care for was the booster wiring. It has two alligator clips on it. Maybe that's so you can move it around before wiring it properly? Now to wait until we get rolling again to see how it performs.
I'm interested to see how you like this one. Good price. Did you take the lifetime warranty for $25?? Seems like a good thing to add!
I didn't see that when I placed the order!! It wasn't there I swear! The manual only says a one year warranty, but the site says three years........HHHmmmm. I just sent an email to them. We'll see what they say.
It's a drop down right below the drop down for the range extender. I think I'd want both. I mean $25 for LIFE TIME warranty. You gotta love that!!
I see that now, but I swear it wasn't there..... really! I agree for that price it would be worth it. The range extender came with my TPMS. I didn't even ask about it when I ordered it since they claimed up to 60' range, but the extender says it should be used when the distance from the unit to the rear most wheels is 25 feet or more. I did ask about the extended warranty in my email to them, so maybe I will get it offered? Time will tell.
In my opinion the short answerer to the OP's question is YES they are worth getting. I'm running the Tireminder TM77 with signal booster & 12 sensors. Early on (about 4 years ago) I had a couple sensors that were intermittent, Tireminder replaced them under warranty. Occasionally will get a "No Signal" alarm generally on one of the inner duals but they clear themselves in a few minutes. Recently had the receiver suddenly show No Signal alarm on all sensors at once. Called Tireminder as there was no way to reset or clear the unit. Explained the issue to Tireminder Customer Service and to my surprise they are sending me a new receiver at no cost, so OUTSTANDING Customer Support, at least in my case. The system isn't perfect but I don't leave home without it.
That's what you call excellent customer service! I'm hoping I made a good choice too. I like the idea of being able to replace batteries in the sensors instead of throwing them away and having to purchase new ones, plus the sensors I got are supposed to be the smallest available. Also the monitor is portable so if I have a problem I can take the monitor to the wheel for verification.
I did get an email back telling me that the standard warranty is three years not one like the book says, so that makes me feel better. I asked about purchasing the lifetime warranty, but haven't heard anything yet.
Two quick questions...is the warning intelligible. IE if it goes off while driving can you tell right away what type of alert it is? And is the quill depressor inside the sensor made of metal or plastic? Thanks...
The warnings are audible and visual. It warns of low pressure (duh...), high pressure, and also high temperature. Far as the depressor, they are plastic. They are long enough that you hear a PSSST before they are tight. There are also lock nuts that you can screw on the valve stem and lock onto the sensors with the wrench provided.
Just spent another $25 on my TPMS for the lifetime warranty. Now even my wife is happy with the purchase!:oops::):)
Careful. If the wife is happy you know you're in trouble. :ROFLMAO:
Been in trouble for so long I wouldn't know how to act if'n I wasn't........ Been married to her coming up on 34 years........
Well, I thought I'd follow up on my TPMS purchase. TWICE since I installed it it saved me. Once when I wound up in freezing rain and ice built up on a sensor to where it came loose causing a low rear tire on the truck (no trailer) on the Kansas Turnpike and again today. It let me know a trailer tire was low so I stopped and filled it up. !5 miles later the same tire was low again. I put my spare on and found a screw in the tread. Wouldn't have known about either one without the TPMS. I figure it paid for itself just with the trailer tire and not having it blow and damage the trailer.
Just changed the batteries on my TST sensors yesterday - easy peasy.
If you get a Tire Sensor that measures pressure and temperature, it warns of not only low tires but can warn of overheating bearings, brakes, etc. A couple of years ago driving down into Death Valley the TPMS was going wild when the front brakes temp exceeded the set temp limit. Nice reminder to slow down and pull over to let things cool down. It was 115-120F outside in the Valley that day.
From Mountain Directory West
