RandyB
Retired
- Nov 15, 2019
- Portage, MI
- Ventana LE 4037
- 40' 11"
- 2021 Chevy Trailblazer
In a separate thread I was asking about adhesive recommendations for sticking an aluminum track back onto an exit window. So far, there is nothing I’m all warm and fuzzy with.
Replacement glass is made from solid gold, apparently. $904 from Newmar. It appears that replacing the entire window assembly is the only means for peace of mind. $210 and it has a screen!
I have the rough opening dimensions for a typical exit window from RecPro. The height is OK, but the hole will need widening by 1 5/8”. That’s no big deal. Easy enough.
For a complete picture of what I’m needing to order, I need to know the wall thickness. Is it safe to assume that all late model Newmars have the same wall thickness?
Does anyone know for sure the wall thickness dimension? Outside skin to inside panel.
2017 Ventana LE 4037, bedroom window, drivers side, in the full wall slide.
