Xcite radio volume and FL Steering wheel control
JJT-NC
North Carolina
Dutch Star
2020 JLUR Diesel
My 2022 DSDP is on the FL chassis. I spend a good amount of time early on to get that Xcite radio set working properly.
One weird problem remains: sometimes the volume control on the steering wheel does not work. And I mean it does not work for a long time, even over power cycling. It didn't work on our previous trip - 1,400miles over 2 weeks.
Then, last week on a short 3 day trip, it worked like a champ!
Any ideas or experience with an intermittent problem with that volume control?
Thanks!
Thanks!
I have the opposite problem. On my 2022 4081 the steering wheel control works but the button on the radio quit working. Call Newmar who got Xite on the phone, sounds like I need a new unit
Our Xite core was changed out a few months ago and the only thing thats not working as designed is the steering wheel volume control... anyone know what wires i should trace to make sure its all connected correctly??
thanks!!
Thanks!
Yes we had that problem and finally no volume at all. Turns out it was the head. Replaced it. River parks used as supplier.
We just had our core/head unit replaced by Riverpark.. the old core/head the volume control worked fine.. new one, nothing yet.. i need to pull the fuse on the FL axxess module and see if restarting it will help,..
Thanks!
Did you get this fixed, what was the issue?
There was a short in a wire bundle under the drivers seat, which caused all kinds of alarms to fire. Once that was fixed, the volume problem also went away!
What was the solution for this issue? Thanks
