- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
The prior pump failed with a red light and blown fuse. This one is showing no indications of failure and I'm also not hearing the "hummm/buzzzz" it usually likes to make. Yes, I'm wondering if a "tap tap tap" needs to occur on the check valve and that is the likely next step. But if it's been working for 2-3 weeks I can't think that a check valve would be an issue. I could be wrong, usually am, but I'd think that would be more of a case of non use. We shall see, for now minimizing making things work and performing unnecessary labor as my labor tank is on empty!O man of exactness, according to your prior post you are perpetuating stupidity. Now, even after chastising you for not following your on rule, it sounds more like a sticking check valve. Is it doing the same thing it was doing before you replaced the "hot water loop" pump?
