Buly
- Nov 3, 2019
- TGO Titusville FL
- Dutchstar 4369
- 2014 Honda CRV
My training is that the only time it leaves the holster is when it will go bang. I do not believe in using a firearm for persuasion. In my opinion threatening with a firearm is a very good way to get dead.It is like knowing which days to use your seat belt, and which days to relay only on your air bags.
Be ready for the worst, and hope for the best. Having a firearm does not mean you have to use it. But it can change the other party's demeanor very fast. Me thinks ?
Or jailed.In my opinion threatening with a firearm is a very good way to get dead.
When they upholster their gun they are ready to kill. I submit that you would be ready to deter.You should tell all that to the cops. Tell them not to touch their gun unless 100% ready to kill.
Good points, @JoeHogan! We have two sayings in our family that sums up our approach. The first is "If you put yourself in a bad place, bad things are likely to happen!"I am going to leave with this, I am not a policeman, nor do I pursue people for whatever. If I see a problem, 911.
Nor do I take an aggressive stance in any situation, unless there is immediate danger to me or love ones.
Avoidance is First, Retreat is second. If an aggressor leaves me no choice, I will attempt at deterrence, if they persist, then and only then will I consider deadly force.
If an aggressor is within 20 to 25 feet, you cannot draw fast enough before they are on you and in my case, chances are good that I will lose. Even if your weapon is out, any delay and you are in hand to hand before you can pull the trigger.
This $hit happens fast.
I am only trying to protect me, my love ones and potentially my possessions. Let's leave it at that.
I'm not sure I want to have to carry a big can like that around with me the whole time I'm getting fuel. A smaller pocket sized option would be better. Did you notice that it is only 2% Capsacian??? (pepper) That must be some bad stuff!!Here is where I got mine.
https://www.amazon.com/dp/B002BMOJXE/?tag=rvf01-20
Here is what I carry. Note that it is a gel not a spray. There is pro and cons with this. However, if you are in a confined space, a gel is much better than a spray. Or if the wind is blowing in your face, with a spray you end up spraying yourself.I'm not sure I want to have to carry a big can like that around with me the whole time I'm getting fuel. A smaller pocket sized option would be better. Did you notice that it is only 2% Capsacian??? (pepper) That must be some bad stuff!!
