- Jan 19, 2021
- Rosemary Farm
- Between RVs
- Toadless
Another little update:
I tried to start a regen again today with the Diesel Decoder and got tired of waiting for it to initiate and gave up, although I only gave it about five minutes. Also looking through the live data it has a field for DPF soot load regen threshold and the value was something like 2.05%, and my DPF soot load is reading 0%. So maybe thats why. Didn’t have time to talk to their tech folks.
I then plugged in the DL handheld, and it initiated a regen immediately. So at this point the Handheld is the only device Ive tried that I will recommend, because it initiates regens immediately and reliably, and also has a field for the after-treatment injector activation. You know when it turns on and can watch the after-treatment temp rise. This gives me complete confidence in the device.
I’m no longer an advocate of the Diesel Decoder, other than for the fact that it gives comprehensive live data, clears codes, is easy to use, and is cheap. For regens, even though the tech guy said it should work, and it did for me once, it isn’t immediate, and I’m not convinced that you can do a regen at any time.
Hope this helps.
Hope this helps.
