- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I put the Wi-Fi paddle antennas on and the Wi-Fi is night and day better. My android phone Wi-Fi signal test went from -90 to -54 by switching to the paddles, i.e. much stronger. Tests on the laptop verify.
This leads me to my opinionated conclusions, based on my antenna mounting location, etc.
- Pepwave antennas are likely better as they are on 6.5ft leads instead of Parsec's 15ft leads. If I did this again I would go with Pepwave's 421 (4 cellular, 2 wifi, 1 gps).
- I recommend the Pepwave antennas over the Parsec but if you go with Parsec consider maybe a cellular only or cellular + gps or realize the wifi may not be ideal for inside the coach.
- I may have experienced better results in my prior setup as I had dedicated Wi-Fi antennas and dedicated cellular antennas, 4 in total on my roof
- Parsec appears to get better cellular connectivity. The pepwaves were elevated so I'm not going to attribute too much to antenna position. As I don't have both antennas available for side by side testing this takes away some merit from this conclusion as I can't test the same point in time.
- Working at the dinette sucks, I miss my desk. I need a better chair that is taller and better lumbar support! The height of the dinette compared to my dinette seat setup will lead to carpal tunnel syndrome, i.e. a terrible angle for me. Need to fix this going forward as I don't to bring the desk back for reasons stated in another thread I believe...makes televator unusable without some effort which I never did.
- I'm leaving Pepwave 2's Wi-Fi to the roof Parsec for bringing in external Wi-Fi sources when available.
