- Nov 2, 2019
- Fulltiming
- London Aire 4551
- Yukon Denali
- Yes
Okay, I'll newgle because I'm not sure what the water pump looks like other than looking at @NWIP's photo. BUT not now....pickleball calls.My water pump was acting up a little and I've known ever since installing this one I may have had a problem with the screen filter on the inlet side of the pump. In Tucson I removed the screen filter as it was a source of an air leak I believe causing the pump to run oddly. If you have an air leak the pump will have problems as you describe. We filter the water going into the tank, in your case like mine we have at least two filters depending on if you use one prior to your water softener that would make 3. You (or Jack) could just go in and remove the screen filter at your water pump and connect the hose coming from the fresh tank to the pump directly, all the same fittings. Mine are quick release, some may have screw on. It's super simple, you could do it. Just detach and reattach the lines going into the pump, if that doesn't work then the line on the other side of the pump going into your coach. You can either detach/reattach the pump connections or do as I did and completely remove the screen filter at the water pump and see how that works for you. I think that screen is overkill and in my case was a cause for problems. No issues since removing the screen filter for me.
Turn off city water AND the water pump prior to doing this.
