- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I'm going back to what I said before, self included - the result of this saga is DEF HYSTERIA.
We are not engineers, we are not chemists. People are putting heat shields in, analyzing DEF at various temps, taking temp readings, boxed vs. bulk DEF, using a small portion of your capacity before refilling, the list goes on. The system should work as installed at full capacity of the tank. There is one manufacturer that seems to have a problem with their code in a circuit board for sensing parameters or properly sending the params at the proper intervals. As a result the RV Diesel/DEF world is going crazy. I suggest we all just calm down and use the coaches as we have been for years and be prepared for any problem as we all have to be as these machines are not overly reliable like cars. Any and every part in our "machine" regardless of manufacturer of said part can fail or have a defect. It is what it is. Stats typically tell the real story of any trending failures.
The biggest lessons learned, IMHO, are to have towing service such as Coach-net, understand the limits and what costs could be, understand there are devices that help you should you be in a location without cellular such as a satellite communicator like the garmin inReach, use your DEF however you believe is best for you but be forewarned of said DEF HYSTERIA.
