Jim
- Dec 18, 2019
- North Carolina
- London Aire 4551
- Freightliner
- Cummins / I6 Diesel Pusher 600HP / 1,950 ft-lbs
- 2016 Jeep Rubicon
The previous owner had the "fix" done to correct the FWS problem. When I bought the coach, the dealer found that one of the zones was inoperative, and they fixed it. But there was also some damage to the floor of the FWS and the dealership sent the coach to Newmar for repair, and Newmar tore out (and replaced) a large section of the FWS floor.You have a 16LADP. The hwh fws had some issues for both 16 &17. The bedroom end would sag down some. This seems to load the main floor right at the end of the FWS. Usually causes some of the tiles just before the master bath area to crack. I have some of those. Have you ever seen the wiring mesh for the floor heat? They are thin and can easily break. A cracked tile 'may' casue damage to the mesh. *IF* that maybe the issue, perhaps you can get Newmar to deal with it.
When the coach finally arrived here, only the Master Bath floor heat worked. Of course, the dealer said all sections worked fine when it left their place and that Newmar must have damaged the floors when they did the repair work. And of course, Newmar said that they didn't damage it, and that it must have not gotten fixed at the dealership. So basically, it's up to me to fix.
The Front area start working after I reset the GFI switch under the sink in the half bath, even though the GFI was showed a green light before the reset. The area that is not working is in the bedroom, and coincidentally, that's in the general area where the FWS floor was repaired. The 2016 LADP doesn't have heated floors in the FWS, so I'm skeptical as to how the heated floor in the bedroom area would have been damaged by work being done on the FWS. But perhaps a wire in that area took some damage.
Thanks for the response!
