CaptainGizmo
- Nov 3, 2019
- Newell
- 2020P
- Cummins ISX
- 2021 Grand Cherokee Trailhawk
@CaptainGizmo @redbaron - Well I finally got the nerve to climb up and check mine ... guess I was just afraid of what I might find. Fortunately all my brackets are in the proper configuration, however the bolts are loose on the very back bracket of the rear awning. I will just keep that one in until I can get to a location and have time to fix it. All the bolts look like maybe 1/4" lag bolts ... any idea what they screw into under the roof. They look like they are pulling out, not coming unscrewed.
Thanks again for posting about this issue ... would of never caught it without you doing this.
FLSteve
I had the samething happen to my 2018 DSDP. I brought to Newmar attention in March 2020, and this it the reply I got back from them. At the time I had 3 bolts that did not grab into anything. I asked if that made changes to newer models to have a thinker backer material since the bolts only went into the fiberglass and about 1/4" plywood. I ended up putting a larger lag bolts.
Newmar runs an aluminum backer plate under the roof material the complete length of the coach to help hold the lag bolts for the brackets. Most likely what has happened with your coach (I think the picture you sent confirms this), is that the installer obviously missed the backer during install. Rather than following the previous directions you were given, I would recommend that you add a lag a few inches closer to the edge of the coach in order to reach the intended backer.
Wait, what? You're kidding...I wish someone had told me that paying $400,000 wasn't enough to get a coach without problems!!How goes the saying? You get what you pay for? You could always order a Newell.
Send us pictures of your Newell and copy of your bank statement after the purchase please. Check out the steerable tag on @CaptainGizmo new coach...Flip a U turn on a regular road.
I know several people with Newells and, while they are very nice coaches, they have issues too. There is no such thing as a "trouble-free coach."Been there, watched that. LOL
And, btw the way, my DS4369 will turn circles inside that Newell. But, I don't care since it's gonna be a perfect, trouble-free coach!!
Ok gang...not real good news, here.
I got the engineering plans and, frankly, they raise more questions than they answer. I've called Newmar and spoken to, yet another rep, and seem to be going downhill in "attitude", but whatever, I have plenty of energy and volume left in me. The rep (Rick) seemed to be irritated with my questions as to the accuracy of the plans vs. how my coach was built. He said, "what difference does it make; just have the repair shop call us and we'll get them the information to get repair done."
I apologized for my desire to know exactly how my $400,000 coach was constructed BEFORE having someone CUT into the roof, if that's NOT what is needed.
Some major questions are on the table, waiting to see what they come up with:
These questions are very important, since they will dictate just HOW the repair shop makes the repair. IF the backer is, in fact, in the right spot but somehow the mount was incorrectly located, it’ll be a VERY simple task of moving the mounts to the right spot and fill in a half dozen screw holes. No hole will be cut in the roof.
- I’m assuming the floor plan is, in fact, a DS4369 even though the graphic is not the right layout.
- Page 1 and 2 are not commensurate with each other. Two different bracket and backer locations!
- WHY did they move (and extend) the backer ONLY on the Driver Side when it’s the passenger side that has the awning and needs the mounts to support the weight of the arms?
- So, the problem is, we don’t know if the wrong roof jig was used on my coach, and the backer AND the mount were NOT put in wrong location. OR, was the backer CORRECT, but somehow, just the MOUNT was put in the incorrect location?
I'm not certain where the problem in production occurred, but for your reference, mine was released in January 2019. These plans were revised way before that, so I don't feel it's a "mid-year" oooopie issue.
