osuallen
- Feb 12, 2020
- Oklahoma City
- Dutch Star 4369
- 43'
- Freightliner
- 2018 GMC Canyon
Newmar engineering has come up with a working solution. This involves a C-Channel that will run between the Center and Front mounts, giving a mid-span point to anchor the awning where the center arm is.
Actually from a structural perspective this is a pretty logical solution. If I am reading correctly, they will add a C channel which is anchored to the front and middle bracket. Then the awning's middle arm position will be anchored to the C channel. Assuming the C channel is adequately stiff and the connection to the roof brackets is also adequately stiff, it will transfer the torsion to the two roof anchor points and the net effect will essentially be no different than if there was a correctly anchored to the roof at the arm position.
