CaptainGizmo
- Nov 3, 2019
- Newell
- 2020P
- Cummins ISX
- 2021 Grand Cherokee Trailhawk
I believe most, if not all, of the discussion so far has been with respect to Dutch Star coaches.
I have not noticed any warping.
God I hope notThis reminds me of the Newmar sani-con saga!
Please read the original post #1 and you will be informed of the problem. This is not about aging Dicor; as you will see from the TITLE of this thread.Curious, if the brackets are not separating from the roof, the cracking on the dicor is about normal for 3 years. It's recommended to replace the dicor at the 5 year point if lots of time has been spent in excessively warm climates, at least I did it on my last unit. I will do it on this one as well, just to be safe. I guess I don't understand the problem. I have the "other style" awning system.
If there is no plate under the roof, welded or otherwise secured to the rafters, which are spaced at 16” - then what would the mounting bracket to which the awnings are secured, be secured to itself? The fiberglass roof? That would not be good.Let me ask, if the channel is on top of the brackets why worry if the coach has a mount under the roof? Aren't we really talking about making the awning strong enough rather than the coach?
