I have a 2004 Fourwinds Majestic build on a Ford E450 Superduty chassis, and I am setting it up for towing my Jeep.
I bought a Brakebuddy Stealth, and installed that in the Jeep. That seems to work (testing shows that the brakes are engaged). I am trying now to install the control unit in the RV. I found the tow package hookup in the cabin (hidden well in the extreme left lower corner), and have an adapter that seems to provide all the connections I need for the controller. The only problem is that the current 7-blade has only 4 connections, wired in parallel to the flat-4. The wiring looks like someone simply spliced the 7-blade into the flat-4 connection. That leaves out the break signal and the power connection required for the 7-blade.
I can certainly run a couple of wires under the car and into the cabin to provide power and break signal, but I am wondering if that should be in place. Since I did find the connector for the tow package, wouldn't it make sense that the rest of the cabling is already in place?
I've crawled under the RV, but could not locate any connectors that would look like the tow package connectors, but I may have missed them. Has anybody done this and can give me an indication as to where those connectors could be hiding?
Thanks.
Thanks.
