SLIDE OUT KILL SWITCH Some Gulf Stream recreational vehicles have a kill switch mounted to the base of the driver’s seat. The slide out will not function unless this seat is moved to its forward most position. Also, the parking brake may need to be applied for the slide outs to function SLIDE OUT CIRCUIT BREAKER SWITCH If attempting to move the slide and its perceived that the slide out system has no power, check the 12 volt 50 amp mini-breaker located in either the front or rear exterior electrical compartment to make sure it has not been tripped. Reset the breaker as needed. Make sure the driver’s seat is positioned as far forward as possible and the parking brake has been set.
