Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
SHOULDN’T be an issue. NIRVC provides removal instructions for this purpose.When I mentioned removing the Rettrobands, she backed up and said she doubted the installer would want to remove them as it's a proprietary product of NIRVC.
Key word, "SHOULDN'T"SHOULDN’T be an issue. NIRVC provides removal instructions for this purpose.
Yes, that's what I told the girl who took the order. She said they need some kind of tool to cut the tire with so they can get at the bolts. So who am I to argue.If the installer has any skill, they should be able to loosen/remove the 2 bolts and remove the Rettroband.
LOL. She may be thinking of something else…Tryon bands?Yes, that's what I told the girl who took the order. She said they need some kind of tool to cut the tire with so they can get at the bolts. So who am I to argue.
If they have a problem removing the Rettrobands, I'm guessing they may have a problem re-installing them. Or, will you have to return to a NIRVC location for the installation?Yes, that's what I told the girl who took the order. She said they need some kind of tool to cut the tire with so they can get at the bolts. So who am I to argue.
Consensus from above is only NIRVC does the installIf they have a problem removing the Rettrobands, I'm guessing they may have a problem re-installing them. Or, will you have to return to a NIRVC location for the installation?
Yeah, have to go to NIRVC for the re-install. But I would have thought just about anyone could remove the Rettrobands. I mean, it's only a couple of bolts, right?If they have a problem removing the Rettrobands, I'm guessing they may have a problem re-installing them. Or, will you have to return to a NIRVC location for the installation?
I hope the installation went well.So tomorrow the install is supposed to happen! I'll report back on how it goes.![]()
Nope, it was a disaster.I hope the installation went well.
