Rich-MLsRV
- Oct 1, 2020
- Colorado
- Ventana
- Freightliner
- 2020 Jeep Cherokee
Can someone recommend where I can purchase the rubber grommets that holds the metal valve stem in place. These rubber grommets hold the valve stem from the inner rim in place on the outer rim. The current rubber valve stem grommet stabilizers slips off over time. You can see in the picture below the valve stem is damaging the rim
as a result of the grommet popping out. I've pushed the ones pictured back in place but over time they pop out.
