- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
In my other thread about AC Heat not working I had a short, a second electrical short in the wiring of my OASIS system. In verifying the wiring ITR Heat had me go to my EMS panel and then turn AC I on and check for an AMP change. I showed +12 AMPS. Then switch to AC I and II and you should see a gain of 12 AMPS on both L1 and 12 AMPS on L2. L2 was NOT showing any change for me. I verified all wiring, wire nuts, etc. and could not figure out the issue. I then removed and reinserted the spade connectors in the 3rd back relay which is related to AC II and now it works. I'm sure I'll now enjoy much better heating via electric than before. This could have been this way since taking delivery and never knowing it so the above steps may help you verify for your own peace of mind that your AC I and AC I/II are working as it should.
