Xite HD 360 Camera System Issues
How do you physically remove the camera? Does the camera unscrew or do you pull the cable from the back?
The camera should have a plastic cover with a bead of silicone around it. Use a razor to cut the silicone and the plastic cover should snap off. You will then see the camera mount which i believe has two screws holding it in place.
Yikes. These are all new coaches.
Two year old coach here. With the present design, as explained here and in other threads, the cameras are powered 24/7 so the likelihood of a failure after 24 hours x 365 days x2 not uncommon.
Are these issues prevalent today in the 2021 lines? Makes you think twice before ordering this expensive option if cameras need to be replaced fairly soon.
I believe the Xcite HD camera system is designed the same way in 2020 and 2021 Newmars. There is no separate power switch to “power down” the cameras when stored or parked.
I have greatly benefited by this thread as another that has had the loss of three cameras now on our 2019 New Aire. Since accessing the HDCMM is difficult ( behind a door, behind the outdoor TV) I am wondering if anyone has figured out a good way to de-power the cameras or entire dash system by pulling a fuse or circuit breaker...just wondering???
Is this 24/7 powered issue applicable to Dutch Star with 360 deg system?
Good timing...
Just this week I had an electrician install a dash switch to cut power to the main Xite unit in the dash and another switch on the partition behind the TV to cut power to the HDCMM unit.
The dash switch helps to eliminate the heat generated by the Xite unit...I had one unused switch on the dash.
The placement of the camera switch enables me to turn off the all the cameras by merely lifting the compartment door and reaching in...no need to pull out the TV and open access door. You just need to identify and tap into the power wire feeding the HDCMM unit.
Gil
Same thing with the dash radio. As some of you know I bought a rocker switch titled "Dash Radio" and installed it to kill power to it. Dash radios are not meant to be always on like in cars. Typically you just need to find the RED wire.
This is a great resource, thanks, The passenger side camera has gone out on my 2019 NA. Called Customer Service, after being told to disconnect and reset I went from a blue screen to a black screen. The advice from CS is now go to a technician. Where can I buy a replacement camera? Direct from Newmar or is there a better source?
Order from Riverpark. Important to pull the plug on the camera system when RV not in use. These cameras are clearly not rated for continuous service.
Thank you turbo, excuse the tardyness, have been cleaning and preparing to put the NA back in storage.
My NA has been sitting in a hangar since the plague started. Now dusting it off and activating all the systems to see if they work. So far so good. Will be going up to Yellowstone in June.
Just back from 2 months in the Keys. Hope to head out west in 3 or 4 weeks ??? Got taillights and dash AC to sort out before that. You make me jealous yours is in a hangar.
Been through 2 of those chassis modules. Hope it is over. My NA spends most of the time in a hangar in Palm Springs. So dry here the coach looks brand new (except for the dust). Only time it sees the sun is on a trip.
I have one of the first NA's, so they must have corrected the installation. Got mine all back together.
Turbo pilot I have a 2020 Newaire with the 360 camera system that several of the cameras have failed. My coach was built in July or August of 2019 and we purchased in sept of 2019. Do you have pictures of the install of your replacements. Thanks. Dave
Nope. Replace front and rear. Both challenging because of the way they were installed. Clearly put on before the cap was set with no thought about having to replace them.
I am working on a DVR setup for the HD360 system. I know the connection is a FAKRA connection, but what I do not know is what kind of signal is being sent. These are called HD, but I think that is a stretch. I am assuming these are probably 480line vs the 240line of the SD, sticking with composite signal.
Does anyone have specific knowledge of the camera being used? A part number would help me in this endevour to determine what signal is available.
Also, for those that have dealt with the power issue, is the FAKRA connector providing power and video signal, or are there separate dedicated power connections?
How don't know how many lines of resolution but it is definitely more than SD. The HDCMM has a HDMI output. Power and video goes through a single wire FAKRA connector.
