- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I almost always overcook, even with the probe. I have a digital one I insert to inspect and always find out I screwed up. The food probe is good as stated above but my recommendation is UNDERCOOK, i.e. lead the temp and then inspect. For example we all hear of the magic 165 number but if you like steaks medium rare you probably want a max temp of around 130. You should consider catching the temp (actual) at or prior to that as you'll be consistent like me finding the temp overshooting at 160+ when you least expect it. You'll learn your grill/smoker, just be prepared for overcooks and stay on top of the actual temps and you'll see how it turns out. So with the included food probe which you can monitor and/or set alarms in the GMG app you'll want to set a point in which you inspect such as 30 deg early.
