flyboy013
- Jul 24, 2020
- Mountain Aire 4531
- Spartan K3
- Cummins ISX12 (500HP)
- 2023 Jeep GC Summit Reserve
- Yes
I don’t have a problem yet, I think. CaptainGizmo's original post showed how his awnings mounts were becoming separated from the roof. I’m guessing this is either due to lack of solid support under the roof, screws that were stripped and thus not holding, or due to excessive weight in the wrong place (ie., mount is attached to the roof in the right place).
Given that this is my first MH, I did not know if the dicor cracking was related to the awning issue, or as you suggest, merely based on age.
Given that the dicor cracks appear to be normal for the age, I have no problems at this time with the awnings other than the fact that the supports are not installed correctly which may lead to premature failure (per Girard). Additionally, I still need to sight down the length of the awnings to verify that there is no warping.
