- Sep 21, 2020
- Ringgold, GA.
- Holiday Rambler
- Ambassador
- 40'
- 2019 Jeep Grand Cherokee
That's better. You could put it on your belt and be ready in case some Yahoo walks up and starts something. I'm still digging something like this..........Here is what I carry. Note that it is a gel not a spray. There is pro and cons with this. However, if you are in a confined space, a gel is much better than a spray. Or if the wind is blowing in your face, with a spray you end up spraying yourself.
The gel is a stream of Pepper material. Like silly string. You can send it out 15' or so. In my case, the more distance the better. Also the cons are you need to hit a vulnerable area. https://www.amazon.com/dp/B004NKSPR8/?tag=rvf01-20
https://www.amazon.com/dp/B01FHDZGGM/?tag=rvf01-20
