- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I agree--the 5ver is sounding pretty darn good.I wonder how many affected or worried about DEF heads may rethink their RV plans. I can see this driving people (self included) away from a motorhome and into a really nice, really big, fifth wheel. DEF problem solved!
Preposition Jeeps nationwideOnly problem is how do I get the 5ver and my jeep where I want to be...thats a heck of a train
That would cost me a fortune!! The amount of time and $$$ I spend on my jeep has rivaled what I have spent *modifying* my Dutchstar. ( not the actual purchase price of the DSDP)Preposition Jeeps nationwide
So glad we got to meet you in better times. Judy D
Also, I would ask that delivery of your new coach include a reserve def head unless the matter has been resolved. Judy@ARD , are they coming to you with the new head or do you need to make the trek to NIRV (Dallas?)?
Your place at Polson is too beautiful to not give it one more shot Tj. Your luck is ready for a turn for the best! Go and enjoy!On a slightly different tack, is there any validated data showing the actual frequency of DEF head failures? Since our coach is a 2018 (apparently near the epicenter of the problem), what are the odds that we’ll experience a problem? We have not had any DEF-related codes…yet. Our primary source of DEF is from the pump at T/A-Petro or Loves. And, like many others, we leave the engine idling when we refuel. Haven’t tried the slides and lawn chairs routine yet, though.
We were going to make one final run to Polson before selling the lot there (and the coach) but now I’m wondering if that is smart until a supply of DEF heads is once again available. There’s quite a stretch of I-90 in Idaho and Western Montana that is pretty short on cell coverage and/or decent places to park a coach alongside the road. With all the recent issues we’ve had, I really don’t need another major headache.
Premier RV Service is scheduled for next Monday. We are in our second night at RV Glass Solutions in Coburg, Oregon, for windshield replacement. The new glass is in and sealed. Tomorrow morning, they want to check (and adjust, of necessary) the windshield wiper contact with the new glass. And, I must say they have been a class act! We are very pleased with all we’ve experienced thus far and expect nothing less on the final day.Your place at Polson is too beautiful to not give it one more shot Tj. Your luck is ready for a turn for the best! Go and enjoy!
BTW, how did Premier treat you?
I had a similar issue a few months ago. I solved it by putting bit of Happy Camper in the water, and let it do its work as the water sifted down. It only took a couple of times before the problem was solved. Judy DPremier RV Service is scheduled for next Monday. We are in our second night at RV Glass Solutions in Coburg, Oregon, for windshield replacement. The new glass is in and sealed. Tomorrow morning, they want to check (and adjust, of necessary) the windshield wiper contact with the new glass. And, I must say they have been a class act! We are very pleased with all we’ve experienced thus far and expect nothing less on the final day.
We’ve had nothing but good contacts with Premier RV Services in Junction City, thus far. In addition to replacing the Girard awning, they will be troubleshooting why our center AC unit is not working and looking for the reason why we have intermittent issues with trying to shut off the engine. Hopefully, that will all go well.
We discovered this morning that the bowl in the Dometic 8300 toilet isn’t holding water. I suspect the flapper valve needs cleaning, but not sure how far into the unit I’m willing to put my fingers to try and clean it when the mascerating blades are running.It’s not a major issue, but will need attention. It’s always something.
Is it dangerous to keep it on while fueling?When fueling do not shut your engine off. I actually did this my last few legs mainly to keep A/C going as it was so hot. I think with the SP/Shaw issues if I was on a SP I'd limit my engine cycles.
What have you read? Very curious about this. RV is at Cummins now for several issues but also have that pesky 4 bars to LOW DEF in 1 minute issue . Sounds like a failed sensor since tank was over half full. Where can I go to study up on this?There is a solution to the Def head. The sensor is using the CAN bus to send a signal that the DEF is proper mixture, and the levels are good. This can be faked. There are many companies that create this type of device, although mainly for the 1 ton diesel truck market, it does also run on the larger OTR trucks.
If it is used along with an actual DEF and DPF in place, there is nothing illegal about it. The fix will just allow the def head to be ignored, and the system will continue to use the DEF fluid.
I have not personally done this, but I do know that this is possible.
You folks are strong contenders for the “Plumber of the Decade” award! The first dose of Happy Camper slowed the bowl leak a bit. After a second application, it is holding water normally. Thanks for a great solution! I’m running a third treatment cycle just to be sure.I had a similar issue a few months ago. I solved it by putting bit of Happy Camper in the water, and let it do its work as the water sifted down. It only took a couple of times before the problem was solved. Judy D
Maybe some TLC??Do you think HC would fix the AC? Uhhhh, never mind.![]()
That would be cool to figure this out Ronnie! Thanks for offering to share and by the way a very nice Jeep!My suggestion would be along the lines of def delete and dpf delete.
It would not be appropriate to link to those sites here since the EPA deems this as illegal in all cases, and treats web sites hosting the information very harshly. You will have to be creative with your research.
The laws, in my interpretation, will allow you to repair a faulty sensor with a dummy sensor, as long as the dpf and def system remain functional. The way to do this is to remove the can connection to the def head and replace with a device that sends good codes.
I am working on such a device and will post up details on how to obtain your own kit.
