Buly
RVF 1K Club
- Nov 3, 2019
- TGO Titusville FL
- Dutchstar 4369
- 2014 Honda CRV
Here is an idea what I did:
Bought on Amazon Nylon coated stainless steel wire 45 lb test: Fishing wire
Crimp sleeves for the same wire: Crimps
Also you can use blue Locktite, but I needed it anyway and got the Green wicking kind: Green Locktite
Below is photo of the tools I used. Screwdriver is not shown:
Start by removing the plastic cover
* Loosen the allen screw holding the wire just enough to insert the wire, but careful not to drop the screw.
* Make a small loop and crimp it. I used my electrical ratcheting crimpers, but they sell crimpers that fisherman use for this kind of work? Use some Locktite before tightening.
I tightened mine 2 years ago, and so far found two loose. When there, check the rest of nots etc.
* Measure and cut the wire about 5" from the very bottom of the door.
* Use the drill with a long 1/8" drill bit or similar to drill hole thru the bottom of the aluminum frame directly (or close) below the top loop.
* Feed the wire thru it, and make another loop. Size does not matter.
* Make sure the wire is slack under the cover, so it does not tug on the latch.
* I used aluminum tape to attach the hanging wire loop to the bottom of the door
The wire when pulled will over ride everything and release the latch. All you have to do is release the bottom loop, and pull straight down.
Hope I did not forget any details, but ask if you have any questions.
