jerryt253
- Dec 7, 2022
- Buckley, WA
- Thor Motorcoach
- Palazzo
- Freightliner
- Cummins diesel
What kind of batteries are in the coach now and how many AH is each battery? I just replace my original batteries with 8 of these. Each of these has 235 AH storage for a total of 940 AH.Needing to replace the coach batteries on my Palazzo. Currently 4 - deep cycle 6 volt batteries. Replace with the same or is an upgrade worth considering?
@Richpatty made some incredible changes when he upgraded the batteries in his coach. And while he went further than most of us will ever go, the data that he shared with us along the way can be very helpful. I would suggest you read through the following thread as there is good info to be gleaned.Needing to replace the coach batteries on my Palazzo. Currently 4 - deep cycle 6 volt batteries. Replace with the same or is an upgrade worth considering?
It may be easiest to replace with the same you have.Needing to replace the coach batteries on my Palazzo. Currently 4 - deep cycle 6 volt batteries. Replace with the same or is an upgrade worth considering?
I added mineral oil to mine a few years ago. I think it worked for a while and probably needs to be refreshed every two years as I'm still putting in a gallon or two of distilled water per year across 8 batteries. I use the flow rite watering system which makes it easier:I've read about people using mineral oil in lead acid batteries. Finally met someone who's been RVing for decades and has been using mineral oil in his 6 volt golf cart batteries for years. He takes out 3 oz of electrolyte from of each cell and replaces with regular mineral oil. I've read of using 2 to 4 oz per cell. He tried using 2 oz in the past and it wasn't quite enough. He very rarely has to add water, it greatly reduces gassing off and keeps the battery tray clean from rust. His current lead acid batteries are 8yrs old. I'm now thinking of going this route when the time comes.
